Thread: Low speed turning clunks?
    May 2013
    WA, South East
    Hi guys,
    I've got 96 Tdi 130, and have got a clunk. Not just a clunk, a specific clunking, only at noticeable at low speeds, while turning as tight as a 130 turns. Sounds like it's coming from the rear end, but it's hard to pinpoint anything in particular. It happened before the new gearbox and transfer box was installed, and still happens now. I've googled and searched but haven't found a lot on it that doesn't seem to relate back to gearbox clunks.
    Any ideas, or thoughts on where I should start this next phase of fixing?
    Geelong, VIC
    Any chance you have a Detroit locker in the rear diff? Mine is a bit like that on occasions.
    The other thing might be a worn CVs - happening in the front but transmitting through the driveline and sounding like its in the rear.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    schuy1 Guest
    OK, check your CV joints and the drive hubs. Jack wheel up and rotate it back and forth. Do that for both sides. Check for noises and excessive movement, listen for noises in the diff as you do it. The front tailshaft unis also can be a source.
    Cheers Scott
    JDNSW's Avatar
    Unlikely if the noise was before and after new g/box & T/C, but is it stuck in centre diff lock?
    Another unlikely one is the A-frame pivot bolts loose.
    Near Seven Hills, Sydney
    Front tyres catching on the radius arms? Direction of sound can be deceiving, I swear every noise is on the driver's side of my County because that's the side the window is always open on..
    Jan 2012
    Bendigo
    Planetary gears in the diff is another.
    Nov 2013
    Id second that it may be a tight rear diff ie a Detroit locker engaging disengaging engaging
    Sent from my GT-I9305T using AULRO mobile app
    May 2013
    WA, South East
    Thanks for the input guys, I appreciate it
    95% sure I just have the big old Sals in the back, but will double check for peace of mind now that you mention it.
    Pretty sure the diff isn't locked , it has an additional light to indicate its locked, and it's not on, but another one I can check.
    Only running 235 ATs, and can't see any scuff marks so don't think it's the tyres.
    I'll try jacking it up and rotating the wheels to see if there is any play.
    I might even try getting a lackey to stand on the inside of a corner as I drive slowly round them and see what they pick up.
    Oct 2008
    Wonder if your rear diff has dropped a cross pin, locking the diff and causing it to load and unload when turning.....
    JDNSW's Avatar
    You have checked for something obvious such as a loose wheel?
