Thread: SOUND PROOFING ROOF
    Aug 2013
    newcastle
    SOUND PROOFING ROOF
    Because of the wind noise I would get from my roof rack, I decided to see what insulating the roof would do to reduce it. Reading the forum with mixed reviews I decided to use the Dynamat directly onto the roof to reduce resonant frequency. Then used 3 layers of 4mm EVA foam to help block noise, and also used dynaliner which I stuck to the inside of the roof lining to add more density to the sound blocking efforts. These weren't all sandwhiched together and suprisingly there was a fair gap between each material to provide that air layer of noise reduction again.
    AFter a bit of messing around getting the lining back on I took it for a drive and it was hard to notice much difference. I headed to sydney the following week and once I hit the F3 it didn't really sound like that there was a great deal of difference in noise reduction, that was until an hour later and I hit a brand new patch of smooth bitchumen and everything went nice and quiet. I could only just hear the wind noise from my roof rack and other then that, it was relatively nice and peaceful. I would get a hum from my front runner rack at times also and that was only just audible when it happened.
    This made me realise 2 things. Just how quiet the PUMA motor is when on the freeway and how much of that noise I was getting before, is coming from the road/tyres. I was going to do the firewall as well but I don't think there is any need to. Whilst accelerating I realise there is a lot more engine noise but once cruising it's relatively quite.
    How do you reduce the road noise??? Tyres maybe, I'm just running the standard Continentals at the moment and I thought they would have been relatively quiet. Are there quieter tyres available??
    I'm not sure insulating the underside of the wheel wells is going to help a great deal but I guess it's worth a try.
    Anybody had great success insulating this area??
    Feb 2010
    sydney
    Well there are these things...
    Expedition Exchange Incorporated :: Discovery :: Land Rover Genuine Parts Rubberized Shock Tower Securing Ring (RBC100111)
    They're a genuine Disco part that fits Defenders. Don't have them myself but I'm keen for you to let me know if they work or not
    Not a road noise solution but you might consider looking at an engine blanket. I put one on my 2.4 and it noticeably decreased the diesel clatter. Surprising considering its size.
    Apr 2007
    Hood liner and lining over the gearbox and footwell decreased noise considerably .
    Dec 2008
    Tewantin, Qld
    I haven't done the roof yet but have completely done the floor area. I recon about 80% of my noise reduction came from Dynamat and foam over the rear "wheel arches" and dyna mat on the fire wall, front foot well and transmission arch.
    Cracka Guest
    I removed the rear seats in the 90 to fit out for touring. I used Stinger Roadkill, its the same type of product as Dynamat. I did all of the floor area and side panels to the underside of the side windows and what I could get in the rear door as well.
    When I installed my Hannibal rack I also got some wind noise (contrary to all the reports I read) so I removed the headliner and covered the entire roof with the Roadkill and then a layer of 10mm formshield which is a closed cell foam with ally backing, I used the self adhesive version, I don't hear the rack noise now
    With all of this and my storage unit in the rear my 90 is as quiet as a mouse, even the mechanics at the dealer last service commented when they test drove it.
    I also just did a mod to my cubby box and while I had it out I used the Roadkill under the gearbox cover plate, that combined with my 'mod' also made a difference.
    My Son was home from Darwin last week and commented that it was actually quieter than his 07 Triton.
    So to your question Voltron, I don't think insulating the underside of the wheel boxes will make a lot of difference if you intend to use rubber matting or similar, it will stop the 'holy s--t' what was that when you get the rocks thrown up. You could use a spray type underbody deadener maybe, but for my purpose and results the dynamat type product and then the storage unit over the top achieved what I needed, quietness from road noise AND the rock strike racket is down to a minimum.
