Results 1 to 10 of 23
Thread: army workshop trailer chassis numbers
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    have just taken possession of a workshop trailer.
    it has body number 565 manufacture date 4/66 on it.
    the manufacturers plate is missing on the chassis and so far i have been unable to find a chassis number stamped anywhere.
    anyone know what format the chassis numbers were in?
    i seem to recall they were 3 of 4 digits but am unsure.
    cant find anything on remlr about it.
    to register in qld i take it i have to get a vehicle build plate and fit it etc etc before trying to register it?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Moruya Heads/Sth. Coast, NSW
    My same model w/shop trailer had no numbers on the chassis, only on the plate affixed by the manufacturer APM.
    I was issued a chassis number by the RTA (NSW) and the mechanic that did the Blue slip stamped the RTA number on the chassis, Regards Frank.
    South East Tasmania
    Were suppose to be the chassis number?
    We have one here but I cannot see any plate or number.
    Brisbane, Inner East.
    My No.5 has a badly stamped number, mostly illegible, on the lower left front corner of the tub. There is a serial no. on an ID plate riveted to the rear of the tub giving the maker as Govt. Munitions Factory, Maribyrnong. Qld. Transport do not recognise GMF as a maker but did accept the serial no. and the trailer make is "home made".
    Edit:- make that Govt. Ordnance Factory.
    URSUSMAJOR
    South East Tasmania
    Thank you for that, the plate is missing in our trailer, I will look to see if there is any stamped numbed in the tub because people have been asking for that.
    Even if I cannot find a number there is not doubt that what we have it is a workshop trailer.
    Chassis # will not be stamped anywhere but on the chassis itself, I searched my 1966 w/shop trailer from head to toe, no chassis # anywhere, serial # on alloy plate on body, RTA would not accept that # and issued me with a chassis #, Regards Frank.
    South East Tasmania
    At the back, on the LHS of the number plate mount I can see 4 1/8 holes and marks in the paint were a plate was riveted.
    Perhaps the army remove the plates before selling the trailers?
    East-South-East Girt-By-Sea
    1.20 MB
    It is probably wise to stamp the actual serial number associated with the body (or associated with the ARN if you know it) into the drawbar before going anywhere near the registry office or inspector.
    By doing it before going to the registry you can point it out and it will get recorded as such. Otherwise as many have found out, you will be issued a VIN that will break the link back to its original identity.
    It is not illegal to stamp an original chassis number into a vehicle that never had one. It only becomes illegal if you stamp another number to change an identity.
    You should probably prepare and paint the whole drawbar after stamping the number so that the number doesn't look like it was done recently.
    Chucaro, Chassis #'s are stamped on the CHASSIS, they may be repeated on a detachable plate, BUT if the trailer has a chassis # it will be on a part of the chassis that cannot be removed, Regards Frank.
    South East Tasmania
    Thank Frank, I got the plate with the following details:
    Manufacturer: Pressed Metal Corp. Ltd.
    Nomenclature: Trailer 1/2 Ton 2WH
    Platform Body
    Contract No: C41 547
    Census No: 10 15 E (The 0 it is not very clear)
    Chassis No: 59
    Date of Delivery: 11/65
