Thread: Cruise control fixed!
    Oct 2007
    Williamstown, Victoria
    I've been at it again today, trying to diagnose a fault with my cruise control, where it would not hold speed, or lately work at all.
    I could not hear the little click any more when I pushed the set button and had no cruise control.
    The first thing I found was the cable was out of adjustment, which is an easy fix, (see pics).
    Next I got under the foot well and found the vacuum switch that rests against the brake pedal was loose in the bracket, thanks to a tiny broken clip, the movement was enough to stop the switch properly engaging.
    I followed this guys idea and it worked a treat, a small screw in the end of the plunger effectively gave me enough adjustment to get it working again, I could once again hear the click when the set button was pushed.
    Cruise Control Patch/Fix, Brake Switch
    Next I checked the hoses were holding vacuum ok, which they seemed to be.
    So I tested the electrics of the pump following this thread: P38 1998 Cruise Control Fix (May help someone)
    I found the pump to be working correctly, but it would not hold vacuum.
    Finally I traced the vacuum leak to the bottom short hose on the actuator (arrowed in the pic). I had replaced the two short hoses recently, but the bottom one was not sealing properly.
    I had a smaller gauge hose laying around in the shed, so I cut that to length, put it on, went for a drive, and hey presto, cruise control working once again, and it didn't cost a cent to fix.
    Hope that helps someone trying to diagnose a cruise control fault.
    Cheers, Pete.
    Aug 2010
    Pakenham
    Quote Originally Posted by PeterH View Post
    I followed this guys idea and it worked a treat, a small screw in the end of the plunger effectively gave me enough adjutment to get it working again.
    I had a smaller guage hose laying around in the shed, so I cut that to length, put it on, went for a drive, and hey presto, cruise control working once again, and it didn't cost a cent to fix.
    Cheers, Pete.
    Thanx for sharing this. It may help me.
    Douglas Park, NSW
    The vacuum switch on the brake pedal isn't needed. Mine had a leak in the line/switch somewhere so I bypassed it altogether & the cruise control still works fine. The electric brake switch still kills it when needed.
    There's a step by step diagnostic procedure in the ETM that is easy to use.
    Poland (I kid you not)
    Pete, you're really going to town on that beast of yours. Jonathan
    Oct 2007
    LOL poleonpom, yes I have been giving it a red hot go of late!
    I'm going to be very busy with work again soon, so I wanted to make the most of the time I had to get as many of those things sorted while I could.
    It's great to drive now, I love it!
    I think I've just about crossed everything off the list...a couple of blown bulbs on the dash buttons to fix...might give the brakes a proper bleed...now what else can I find?
