Results 1 to 10 of 20
Thread: Allisport I/C
    Apr 2013
    Cairns
    Allisport I/C
    Well after spending lots of money on an Allisport double core I/C, I spent the weekend pulling everything out of the engine bay that was in the way to make it fit. I then thought I'd simply just pop the new intercooler in along with the modified bracket. put it all back together, an voila. Not so. I have factory A/C (1995 Tdi 110) which I was assured wouldn't be a problem, as the I/C was designed to fit with this. The I/C hits the evaporator, I then tried spacing that forward, which helped a bit, but then I found the captive nuts on the frame where the evap bolts to rubbed on the side of the I/C, plus the frame rubbed on the top end tank. So, to cut it short, there is absolutely no way this will fit in my car, short of owning a fabrication shop to make a new front end radiator I/C mount. Bit of a bummer I must say after hearing that they can make quiet a difference.
    mick.
    Oct 2006
    canberra
    I think the Aussie a/c is different to the uk a/c
    Dec 2012
    Greatest city in Australia, Darwin!
    Dude it can be done! The double core intercooler is a fair lump but the benefits will outweigh the negatives with this thing. Bushman83 (Brett) installed one on his tdi so you can check his thread in projects and tutorials for some photos etc on how he put it all together. I went the straight replacement and it still required some mods in my old tdi, but then it's performance made it so much more drive able.
    Best of luck!
    Douglas Park, NSW
    Quote Originally Posted by 460cixy View Post
    Yep, 'factory' A/C on a 1995 Defender is an AMC kit, fitted once the car arrived in Australia.
    Presto's Avatar
    Presto is offline ChatterBox Silver Subscriber
    Apr 2010
    South Brisbane
    Hi Mick,
    I've been through exactly the same thing, and although the service from Allisport is second to none, Andrew could only confirm that this A/C unit is different to the UK version, so fitment had not been checked. His advice was to try elongating the holes in the base plate so the intercooler sits further back, but I wasn't keen on the idea. Instead, I modified the bracket that the A/C condenser mounts to, pushing that forward to give me about 2/3mm clearance with the I/C. Seems good so far!
    Grant
    Presto's Avatar
    Apr 2010
    South Brisbane
    On the performance side of things, I had fiddled with the pump prior to fitting the double core I/C, and found that the pump mods made a much greater difference than the DC I/C over the std unit. All it seemed to do is reduce the EGT's a little which will allow a little more boost, but not as big a difference as just the pump mods.
    Apr 2013
    Cairns
    Absolutely no way can I fit it. The evap cannot move froward more that 5mm or so due to the support rods for the bonnet catch, plus the evap fan would then hit the grill. The only way I could think of was to cut the locating pins off (which is a pain as they are welded from the inside of the end tanks) then re weld them to space the I/C further into the engine bay. This would then mean major cutting of the fan shroud, as well as the I/C hitting/rubbing against the one piece rad hose. In the end I really didn't expect the car to turn into a rocket. I knew that when I bought it.
    Presto's Avatar
    Apr 2010
    South Brisbane
    I got the same conclusion, but somehow managed to find the space by loosening everything off and modifying the condenser bracket. I had to go at the fan cowl pretty hard too. Even if you do decide not to fit the I/C, I highly recommend doing the pump mods, as although it doesn't turn it into a rocket, it does make a HUGE difference!
    Oct 2007
    Wantabadgery, N.S.W.
    I too have found the installation of the double core intercooler is fouled by the australian air-con. I'm trying to find a solution this weekend. Stand by.
    Don.
    Mar 2012
    Bundaberg
    I got my uprated Allisport i/c to fit. Certainly its not a simple old out new in job.
    Did mine over 12 months ago so can't remember the exact details and measurements, but very pleased I persisted with the fitting, the results together with the pump adjustments were definitely worth the effort.
    Did not make any changes to the new i/c
    I moved the passenger side of the a/c evaporator forward on to some new brackets, and I think some spacers on the drivers side.
    I cut the piece of the plastic radiator shroud off that goes over the old i/c. Then using thin aluminium sheet made up a curved piece to continue the shape of the remaining shroud and pop riveted on to the shroud, so that the fan was still enclosed to suck air through the radiator.
    On mine there is no shroud on the engine side of the new i/c.
    When I finished mine I had to bend a Z in the bonnet secondary catch and cut the top radiator holding plate for it to go through so that it didn't hit the a/c evaporator.
