Whether there is an engineers plate will probably depend on when the conversion was carried out (many were done before such things existed) - but unless it was recorded by Vicroads, you will, I assume, have to get one. The quality of conversions varied enormously, but the major likely problem is pretty much independent of this - some of the adapters were less than accurately made, so the engine and gearbox are not aligned properly. This will result in early gearbox failure. The other question you need to ascertain is what clutch (and flywheel) the conversion has, so you know what parts to get when necessary. You should also note for parts ordering purposes whether the original engine was a six or a four (easiest is to note the firewall shape).
					Reason: spelling
