Nice work ! Certainly paid off with that massive drop in temp.
Does any know if this type of modification is available for a PUMA ?
I know it's been done before but thought I'd share some results, vehicle is a UK 90 TD5.
I have an engine guardian which also monitors external gearbox temperatures, pre modifications towing the camper trailer saw temperatures upto 90 deg C and an uncomfortable amount of heat radiating from the hand brake area after approx 3 hours driving.
Since it's a UK car I had to source a thermostatic valve for the gearbox, I then ran pipes to the front of the car and fitted a 10inch oil cooler behind the winch. Next mod was to fit an extended sump to the transfer box which nearly doubled oil capacity, then finally wrapped the centre section of the exhaust, (centre box removed).
Drove upto Denham from Perth over 2 days, both 6 hour days with the camper loaded on the back and gearbox temp was sat around the 72-74 deg mark, speed was 100kph for most of the time.
 ForumSage
						ForumSage
						 ForumSage
						ForumSage
						FWIW the external sump for the LT230 I know of add approx 500-600mls, far from double the original capacity
 OldBushie
						OldBushie
						 ForumSage
						ForumSage
						 OldBushie
						OldBushie
						Yep,took the muffler out the other day,the cats going and plenty of insulation going on,the floor can get too hot to touch. Pat
 ForumSage
						ForumSage
						EXHAUST HEAT WRAP BLACK 5M X 50MM ROLL + 8 STAINLESS TIES - MANIFOLD INSULATION
Is this the sort of stuff you are wrapping around your exhaust@ $15,. Looks like an easy win
apologies to Socrates
Clancy MY15 110 Defender
I think it adds 0.8 of a litre so double was an exaggeration, but original oil capacity is just over 2ltrs so nearly an extra litre is a substantial increase. I'm sure you could work out the exact percentage increase but I ain't personally that anal.
The exhaust wrap was just the stuff you buy in Repco.
