Results 1 to 10 of 12
Thread: to gas or not to gas that is the question
    casterbased Guest
    i'm just a poor student , and i'm spending $100 a week in fuel on the 3.9
    i don't like gas, but may be forced to use it
    what do u guys reckon
    i want to build up a kit myself, has anyone done it on here
    what would it cost :?:
    Narre Warren
    Don't know about DIY on the gas system. I think you need to have it done by an authorised fitter otherwise you could end up in more poo than Batman without his batbelt.
    You've got a few options with how you have tanks set-up, from replacing the main petrol tank, to using the cargo bay. I opted for the 3 scuba size tanks in the back. This sacrificed a bit load area but kept my petrol capacity in tact.
    If you are planning to install a turbo or supercharger ask around. Backdraft when you shut of a throttle with a charged mixture can be untidy, hence why many taxis have rubber straps holding the top of their airbox on. (It gives a bit rather than shattering if they get a burn in the inlet tract).
    That said, I have never had a problem with mine. Just make sure that you run petrol through the system at least one day a week, given the information you have given on your fuel consumption.
    Mandurah. W.A.
    I was fortunate that my County was already on gas when I bought it. As previously stated it has to be fitted by a licensed LPG installer.
    The current price of LPG here in the west is @ 0.45c/litre, less than half the price of unleaded and certainly lightens the load on the wallet. I have 70litres of usable gas and average 350klms for a tank and thats towing a camper trailer with a somewhat tired 3.5. Another bonus is the clean burn of LPG, your engine is kept a lot cleaner using gas. Also good offroad, gas is unaffected by extreme uneven terrain unlike a certain brand of carbie on petrol.
    The gas tank location can be a pain, mine is located RHS rear, however I relocating mine in the well ( still inside ) between the rear guards. It will be 170mm higher than the guards but with a cover built over the top there is still plenty of room for the handbrake and myself to sleep on top in the back.
    Also, I am sure there is a $500.00 rebate when you have LPG installed.
    Go for it.
    Newcastle Area
    As stated, tank location is a big consideration.
    If you want cargo space, then don't install the tank in the back.
    I've seen a few versions.
    Tank installed longitudinally on the RHS. This allows the back seat to folded, and allow more space.
    The other option is behind the seat. This negates folding the rear seat as nothing is achieved.
    I have two tanks installed where the petrol tank was.
    About 60ish L useable .
    I also have a spare wheel carrier, so cargo area is fantastic.
    I also have sill petrol tanks which hold about 35L each.
    I mainly run on gas, and get about 20-25L/100Km, but the cost is minimal.
    My '86 RR was on LPG and had no problems with backfire.
    Unlike a Disco, fitting scuba tanks into a Rangie takes up too much room. The Disco has extra headroom so it's not as bad.
    On my '86 the tank was fitted fore-aft on the RHS and tucked under the window so it didn't intrude into the cargo area to any significant degree. See http://members.optusnet.com.au/thebecketts...overmod.htm#lpg
    I recommend a system that starts the car on petrol and automatically switches to LPG at a certain RPM - about 1400 rpm on my old '86.
    My current RR has the tank crossways behind the seat and is a pain in the backside. The control is manual as well so you have to remember to switch back to petrol for cold starts. It's a pig to start on LPG when the engine is cold. It was expensive (for the previous owner) and not a good installation in my book and I would never recommend this installer (near Maroota in Sydney) to anyone.
    Backfires have been a real problem and I've destroyed two plastic airboxes (damn expensive on P38A Rangies) so I've fitted a Disco steel canister filter - see http://www.rangerovers.net/rrupgrades/airb...rbox/index.html
    Ron
    Newcastle Area
    Mine's the exact opposite.
    Starts immediately on gas, and a little reluctant on petrol.
    Williams West Aust
    Hi Casterbased
    In WA we get a GOV rebate of $500 for a conversion,EVEN IF SECONDHAND gear is used.
    Legally you cant do the gas work yourself,but if you have a friendly installer you may be able to fit the hardware yourself.
    Secondhand parts are OK,new gas lines have to be used.You would get a cheap conversion by getting everything from a wreck,mounting the tanks/valves yourself and getting a friendly installer to run the new gas lines and sign off on it.
    My Bro has done 2 conversions this way recently,a XC falcoon which cost him about $100 less than the rebate and his 2A wagon which cost him a couple of hundred more than the rebate(had to buy a new special tank to fit the chassis rails).BUT he does have a good mate who is a gasfitter.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Didn't the Federal Govt also introduce a rebate at the time they introduced the LPG excise in order to offset the suddne drop in LPG installations?
    I knew WA did that and have been searching for a similar thing for NSW or from the Feds.
    Ron
    Maryborough QLD
    Regards to fitting LPG DIY I know a couple of blokes in my club who have converted there Rangies with a couple of minor hiccups.
    I know it's not cheap, but I would rather pay someone to do it professionally than myself. I could fit it no worries, but blowing myself up is not a downside I would like to risk 8O
    I'm in the same boat as you, notytol thrilled about LPG, but may be forced to in the not too distant future.
    Regards,
    Trav
    Newcastle Area
    The 79RR 4.4 on gas is my first gas vehicle.
    I also have an Ford XE 351 (which is for sale), and I wish I had converted it gas.
    The cost saving in fuel is quite dramatic.
    Power is not noticably down, so overall, I recommend it.
    IF you are handy, source the parts second hand and install them yourself. Then get them connected professionally.
