Maybe start with braided lines and a fluid change and go from there?
 Master
						Subscriber
						Master
						SubscriberHey all,
Thinking about going to 35s and was wondering if there's any brake upgrades I can do to my 130 puma to make it pull up a bit better with the bigger boots?
Thanks in advance
Cammo
At an absolute level that's true, but I find they increase initial brake performance sufficiently to effectively reduce stopping distance, which is a functional proxy for increased braking (IMO).
Combined with new fluid it might be a good start before dropping coin on bigger calipers, etc?
Cammo,
There is no doubt 35" tyres reduces braking quality. I have branded lines & fresh fluid and braking is still wanting. A while back I was bouncing ideas around with Gordon Shaw from Opp Lock Rockdale, as far as I know you can bolt on slotted discs on the front and you will get some improvement. The significant improvement comes with a caliper upgrade. I have not considered that upgrade so have no idea what aftermarket brands would be a bolt in upgrade. Maybe take cues from the UK tuners like Icon and Overfinch.
MLD
The slotting and drilling of rotors actually reduce the initial effectiveness of the brakes,due to the slightly reduced surface area of the braking surface.What they can do is improve braking due to heat dissipation,where the brakes may have been working hard and there is a lot of heat built up,which usually leads to brake fade.
Wayne
VK2VRC
LowRange 116.76:1
 Master
						Subscriber
						Master
						SubscriberThanks for all the replies guys. With the 35s will come lift, and hopefully more flex, so that will mean longer brake lines - and I'll definitely get braided lines then. I was leaning more to different rotors/pads/calipers. Drilled/slotted yes but maybe bigger? Looking for legal bolt on mods if such a thing exists. I'm interested in the idea of bigger calipers..
MLD,
Do you plan on going down the caliper upgrade path? Or try anything else? Or will it just be a case of adjusting driving style and being aware of how the truck performs under brakes now?
 OldBushie
						OldBushie
						EBC pads on slotted rotors are the go,or you could go up to 6 pot calipers.Google EBC's site. Pat
 ForumSage
						ForumSage
