Results 1 to 8 of 8
Thread: engine running rough
    Aug 2009
    South Australia
    Unhappy engine running rough
    2002 d2 td5 auto
    Hi,
    Hoping for some advise. Just returned from a fairly lengthy trip. refuelled 6 times during the trip (SA Eyre peninsular and back). Weather atrocious, rain, sometimes heavy, during most of the drive. Now I'm getting intermittent rough running, with a lot of engine (I think) vibration, which means I cant exceed around 80k. Stop the engine and restart and USUALLY all ok again.
    What I'm thinking is a bad load of fuel somewhere, but in that case why intermittent?
    Any advise much appreciated.
    Bacchus Marsh Vic.
    For a starting point have a look at the red plug on the ECU.
    If the injector loom is weeping oil into the main harness it could cause your symptoms.
    It could be bad fuel or a list of other things too.
    Is it blowing black smoke when it plays up?
    Is the turbo wast gate jammed or tight?
    Is it possible the intercooler hoses are delaminating?
    Are the hose on the wast gate modulator OK?
    Let us know what you find.
    Cheers, Kyle.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Free Again Thanks Dan
    Quote Originally Posted by alien View Post
    Cheers, Kyle.
    X2 in that order the loom first
    Aug 2009
    South Australia
    Thanks for the 2 replies. Further info: I checked it on a Nanocom and it lists several faults as: "Injector 2 peack (literally) charge long (current)".
    Apart from the obvious inj 2, can someone plse explain the rest?
    May 2013
    Aberdeen Scotland
    Injector peak
    Injector peak charge too long would point to a fault in
    the injector harness under cam cover.
    It usually means that you are not getting a good conection to
    an injector the oil is acting like an insulator.
    This may be checked by going onto live data on Nanocom you
    might also see a higher figure in the cylinder imbalance number
    for that cylinder 0<5 is really good 5<10 is ok above that is a
    problem.
    These figures are at idle only when reved figures are of no use
    you want to measure at a constant speed.
    It could be a fault at certain temp or speed you might get it cured
    short term by cleaning conections at all point between the
    injectors and the harness multi plug.
    If you have not replaced the harness in the last 3+years 50k
    it might be worthwhile fitting a new genuine harness (leoni)
    to iliminate a possable fault the longer you run the engine with
    the fault the more damage you will do to your engine.
    Aug 2009
    South Australia
    Many thanks for the replies/suggestions. Turned out to be the old "oil-in-the-wiring-loom" problem.
    My trusty Landy mechanic sorted it - in return for a few dollaroes - and she's all sweet again.
    May 2009
    Tatura, Vic
    Has there ever been a permanent fix for this problem?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Bacchus Marsh Vic.
    Quote Originally Posted by d2dave View Post
    Remind me when we meet at next weekends trip and I'll fill you in on what I did to mine.
    Cheers, Kyle
    The Good Oil.
