Results 1 to 9 of 9
Thread: Rubber Rings for Instrument gauges Series 3
    Apr 2014
    Australia
    Hi All
    I stripped the instrument gauges and the rubber rings between the glass and instrument rings fell apart ........ do you know if I can get these anywhere ?
    Craig
    Feb 2014
    Craig,
    I dont think you will be able to buy them.
    I suggest you make your own out of cardboard or thin gasket material which your can get from auto parts shops
    Phil
    Ipswich QLD.
    Give these guys a try, Lionel Otto Instruments automotive and motor cycle instrument repairs and restoration they are in Brisbane. The owner is a member here. I am sure they will have what you are after.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Gosnells
    Look for suitable sized O rings. A hydraulic supplier/repair shop would be the place to go.
    But a neatly cut cardboard or plastic one is WAY cheaper !
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i used o'rings on mine
    worked a treat...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Apr 2014
    Blair Athol, Adelaide South Aust.
    I bought some on ebay uk. they were just big thin "O" rings. ripped off
    Cheers Rod
    O-rings from your nearest bearing shop or hydraulic supplier.
    darwin, nt
    I carefully split some spare electrical wire so I could use the insulation as a seal. Maybe not as pliable as an o'ring but cheap, and it left me with some copper wire to use as a port-cleaner for carbies etc.
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (still resting quietly), 74 S3 109" pet4, plus 19 other parts/project cars (2xS2s, 7xS2As, 10xS3s).
    madmax Guest
    you can buy the rubber for the gaskets by the meter, you can cut it to length and glue it up... we do it all the time at work for those odd sized gaskets... you can use super glue, but a silicone rubber glue is best
    Matt
