Thread: Inte-axle diff locks
    wildweels Guest
    Hi I was just looking at a perentie on ebay and saw a couple advertised with vacumn operated Inte-axle difflocks this is the first time I have seen perenties advertised with these are they fitted to all military 110,s
    Cheers Noel
    May 2002
    Heathcote (in "The Shire")
    Just the standard centre diff lock, earlier 110s and Rangies were vacuum operated.
    Martyn
    Queensland
    The two rear axles on my 6x6 came with factory vacuum interaxle diff locks.
    The actuator is the same unit as the LT95 centre diff lock.
    33º 29' S 150º 13'30" E
    Yes, in the Transfer case differential, not the Axle differentials.
    Queensland
    All three actuators are the same.
    The two interaxle ones and the transfer case centre diff one.
    I would hardly think mine is a one off. There must be others around too.
    Near Seven Hills, Sydney
    Quote Originally Posted by 123rover50 View Post
    Your sixby likely has bits from LRPV development or from an LRPV itself. AFAIK there haven't been any auctioned via AFM that have cross axle diff locks.
    As others have stated, it'll be the centre diff lock, the seller is probably a confused Jap 4WD afficionado with no real idea or else trying to con a sucker in...
    Of course, someone could install a Maxidrive locker in the Sals, as they are still available and usually vacuum operated.
    wildweels Guest
    Thanks guys for the info thats what i thought they weren,t axle diff locks but just thought I would ask to be sure .
    What is your comment Barefoot Dave
    Cheers All
