I've always done this by cracking the bleed nipple and forcing the piston back, I use a big old pair of blacksmith tongs but a lever will suffice. If you have an assistant, best to close the nipple before the piston bottoms out, to avoid ingress of air through the nipple when the piston stops moving.
Pull one pad out, push the piston/s on that side back as above, put the new pad in, take the other pad out and do the other half of the caliper. If you pull both pads out, the pistons on one side of the caliper can pop out when you compress the other side.
