Forward of the B pillar they will be the same over all three wheelbases. The only real difference is how much "stuff" is between the axles. The 90 also has a different rear axle, and I believe the spring hangers are slightly smaller, but all the suspension linkages are the same across all three wheelbases. The 90, 110 and 130 are all evolutions of each other so for the most part, they are all the same.
