Results 1 to 10 of 16
Thread: Puma ECU and inertia switch, no start
    Piggabeen (Tweed Heads)
    Hey Folks
    As mentioned before I have a business on an Island in Vanuatu and have inherited a 2010 130 Puma. Now I need to know if I can do a re boot or hard reset of the ECU and can some one tell me the location of the inertia switch. I have fuel primed up to the injectors but it will crank but not go.
    Any help or ideas would be great. We do have dodgy internet workshop manual but its not much good.
    Justin
    Ideas
    Quote Originally Posted by DRanged View Post
    Hey Folks
    Justin
    Any one???????????????? any ideas????????
    Justin
    Kingston, Tassie, OZ.
    Hi Justin,
    I need some More info, IE what caused the no start issue? Are the remote key/s functioning? Is the dash LED etc illuminated? I have a suspicion it has an issue with the alarm immobiliser ECU, tropical environment etc and moisture don't fare too well. It is the same as the earlier 110, 10AS Lucas alarm unit and yes they do have issues with moisture etc.
    JC
    more info
    Hi Justin,
    JC
    Hey JC long time between drinks mate.
    Ok no remote on key fitted. Will check dash LED tomorrow. Local Ni van mechanic was playing with it after the Island got a heap of fuel delivered with more water than diesel in it. Has has all new filter, mount and Volume control valve fitted. This is a l/h drive delivered vehicle 2010 model. What colour would the LED be???
    Justin
    the LED is red....
    Aug 2012
    Tewantin (NOOSA area)
    Would reckon if there is no "remote" it will not start.
    The remote is needed to tell the ecu that it has the correct key and driver.
    The remote locking fob contains the "radio/wireless" information that the ECU needs and must be hanging adjacent to to steering lock. Somewhere in the vicinity is a sensing coil that reads the "remote" No remote no start!
    RF
    Maybe if you can get it flatbeded to a dealer they can put it in the computer and turn the immobiliser off for you
    I have to agree with Rick that if there is no remote its possibly you won't get a start
    Feb 2013
    Sydney, NSW.
    Sorry Dullbird, not having a go at you, but I laughed just a little when I read that statement.
    His nearest "Landrover dealership" or someone that has specialised in land rovers is approximately 123 nautical miles or 227 kilometres away (or two islands).....
    Not much infrastructure or support on Tanna island for "new elctrickery Land rovers"......
    Anyways, DRanged,
    I think your closest technical support may be,
    Pacific Autronics,
    PO Box 1141, Father Walter, Lini Highway Port Villa
    Santo Vanuatu
    Phone: +678 27800
    But what technical capacity or capability they may have for the newer Landrover Defenders, I do not know.
    Regards,
    Mike.
    n plus one Guest
    Got the manual in the 'glove box'? Have a look for the EKA code - either in the manual or on a paper card somewhere in the truck - I think you should be able to get the truck started with that code and the key?
    Last edited by n plus one; 19th May 2014 at 10:21 PM. Reason: Spelling - damn iPhones!
    Australia
    Disregard, sorry had to re read the post.
