Results 1 to 9 of 9
Thread: Solar panel advice
    Mar 2012
    Solar panel advice
    Does anyone have any experience with these solar panels?
    I am after something to run a waeco cf50 and keep my dual battery topped up.
    http://www.ebay.com.au/itm/100W-Watt...fb949fa&_uhb=1
    Feb 2012
    Sydney NSW
    For the same price you can get a foldable 150w. Unless saving weight is your priority. Those flexible one are not very robust.
    Quote Originally Posted by Leyland1980 View Post
    100W Watt Flexible Solar Panel Semi Flexible Solar Panels 12 24V Battery Charger | eBay
    bad juju for what you want
    Quote Originally Posted by jackiec View Post
    I agree.
    the flex ones are good when you want to conform them to a shape, then not move them and not hit them like say the bridge wing on a boat or on the face of a water tank.
    Adelaide Hills - SA
    I have just bought 6 of these for my camper build.
    The weight difference between this type of panel and the traditional ones are enormous. A normal panel weighs about 17 or 18 kg. These thin panels weigh 1.5Kg. For me that's a saving of about 100Kg.
    Also - because of the height of our vehicle, they are a saving in height too. The panels are only 1.5mm thick and the connector block is about 15-20mm thick.
    We are attaching them to the roof of the camper with double sided tape. It is a special German tape - industrial strength.
    HTH
    David
    Adelaide Hills - SA
    This is the tape, in case you were interested. Quick postage - got it in about 2 days I think:
    Ultra High Bond - Clear - 0.5mm thick - Double Sided Tape
    http://www.tapesonline.com.au/double...ow-energy.html
    ahumbert Guest
    Hi
    These panels also do not appear to come with a regulator. If this is the case you will need to purchase one and have it fitted between the panel and your battery other wise you will fry your battery.
    Allan
    Adelaide Hills - SA
    Oh yeah - I forgot the mention about the regulator.
    If you want a good one, a proper MPPT one, then get one of the GSL range. Made in Australia and excellent technical advice over the phone.
    GSL Electronics : MPPT & BMPPT Solar Chargers
    I got one of these: GSL Electronics : MPPT 60-1 / MPPT 60-2
    HTH
    David
    May 2003
    On The Road
    Quote Originally Posted by spudboy View Post
    HTH
    David
    Pics in the build thread??
    Adelaide Hills - SA
    Haha - not quite yet - but they are coming!
    At the moment all the solar stuff is sitting in a spare bedroom waiting for me to get around to fitting it.
    It won't be a big job, probably do it all in a day, but I want to get the gas/water connected first.
