Results 1 to 10 of 11
Thread: Do I need new shocks for Alice - Birdsville?
    Babs Guest
    Hi guys planning on doing "Drive for Life" in Sept/Oct. Alice Springs - Birdsville.
    I have read a lot of good comments on how good the standard shocks are on the Puma and would have thought they would be fine on the corrugated roads, but my old mechanic who's leading the trip is strongly advising for me to get aftermarket shocks installed.
    What's your experiences with the standards?
    Should I be going aftermarket?
    If I was to install aftermarket I would more than likely go with Bilsteins.
    Your input is appreciated. Cheers.
    Sent from my iPhone using Forum Runner
    Nov 2007
    On the road.
    Are yours suspect? How many km's?
    Drive for life are good, know someone that has organised a few, call David at traction4 in artarman, good honest advice.
    Good on you for supporting their cause. :8
    in the wild New England, NSW
    by all reports the oem shocks are ok
    I have had good experience with bilstein performance
    "Drive for life" ? is there a website ? the only one that comes up from google for 2014 is in Vic
    Babs Guest
    Quote Originally Posted by 87County View Post
    by all reports the oem shocks are ok I have had good experience with bilstein performance "Drive for life" ? is there a website ? the only one that comes up from google for 2014 is in Vic
    There should be a link on that same site for Alice. Have another look.
    http://www.drive4life.com.au
    Aug 2009
    Kilkivan
    The original Puma shock absorbers are good and don't need changing unless they are very high mileage or defective. They will run reliably for well over 100k and not need replacement. Try pushing each corner of the vehicle down one at a time, and see that there is strong resistance. If there is not then get them looked at.
    What is handy to take with you is replacement rubbers, for top and bottom of the shocks. They do wear out and sometimes need replacing, and they are easy to carry with you.
    Have a great trip
    numpty's Avatar
    numpty is offline TopicToaster Silver Subscriber
    Nundle
    They're probably the same as the ones on the earlier Td5's and if so, they shouldn't need replacing.I replaced mine with Bilsteins at around 150000 k's (2012) after they'd done quite a bit of hard work including the Madigan Line in 2008
    Numpty
    REMLR No 143
    Apr 2012
    Windsor NSW
    I recently completed a 6,500klm trip which included flinders ranges, oodnadatta track, Simpson desert, birds vile and Cameron's corner on standard shocks. They had about 40k on them and they performed beyond my expectations. I was carrying close to a tonne and never experienced shock fade, including the track from oodnadatta to Dalhousie ( arguably the most corrugated road in the country).
    Babs Guest
    Quote Originally Posted by David Hawes View Post
    I recently completed a 6,500klm trip which included flinders ranges, oodnadatta track, Simpson desert, birds vile and Cameron's corner on standard shocks. They had about 40k on them and they performed beyond my expectations. I was carrying close to a tonne and never experienced shock fade, including the track from oodnadatta to Dalhousie ( arguably the most corrugated road in the country). Dave
    Thank you for that info.
    I will be keeping the standards
    Aug 2012
    In one work NO! Just did it in my 110 2014BY ,
    Easy!
    Safety Bay
    Quote Originally Posted by Babs View Post
    Get a new mechanic,your vehicle will do it fine. Pat
