Results 1 to 9 of 9
Thread: What is this part?
    Jan 2009
    Kuranda, Far North Queensland
    What is this part?
    Behind the instrument panel of my S2A FFT, mounted on the firewall, is a small (about 2cm long) rectangular box with two double electrical connections. These are labelled B and I. The only other info is that it is made by Smiths UK.
    Can someone please tell me what this is?
    Howard
    May 2008
    Bundaberg Qld
    Pic ?? but sounds like a voltage reg or stabiliser
    Jul 2008
    what about a flasher can
    Do you have the later dash with the thermo gauges? These run on nonimal 10v which this device provides.
    Aaron
    Jan 2009
    Good thought, but no - definitely not that. I will photo it tomorrow and post here.
    Howard
    Quote Originally Posted by chopper View Post
    Aug 2010
    Sunbury, VIC
    Does it look a bit like this? If so, as mentioned it's the 10 volt regulator for the gauges. 'I' is the female terminals, and 'B' is the male terminals.
    If it's knackered, it's easy and very cheap to replace with an electronic version. I bought a pack of 5 for a few dollars from RS components. They can be soldered into the existing housing fairly easily.
    Sounds like the voltage stabiliser as bacicat has pictured.
    Jan 2009
    It looks exactly like that! Thanks.
    Howard
    Quote Originally Posted by bacicat View Post
    May 2008
    Bundaberg Qld
    problem solvered
