If the play is as great as it appears to be, then that is certainly one of several things that can contribute to a clunk.
I think the amount you have there might be similar to the wear in mine. I replaced them with new HD flanges and it reduced, but didn't eliminate the clunk. I have a little bit of wear in several other places too.
You may find the same ie that you reduce the clunk, but as there are so many other things that can contribute, you may not get rid of it completely.
EDIt. I just noticed that you said, "with the handbrake off". How much less is there with the handbrake on?
