Results 1 to 3 of 3
Thread: Isuzu / LT95 spiggot bush loose. (AYG320).
    NW Tassie
    Hey all,
    I had cause to remove the LT95 from my Perentie yesterday (don't ask!) and on inspection of the spigot bush assembly, found I could turn it in situ, with finger pressure. After reading this thread: http://www.aulro.com/afvb/projects-t...g-housing.html
    I'm assuming the steel spigot extension should be at the least, an interference fit into the crank recess, is this correct?
    Any help greatly appreciated.
    Thanks,
    Daryl.
    near enough.
    hit it with some 680 or 690 and put it back.
    NW Tassie
    near enough.
    Sounds good, thanks. Might make sure it's concentric before doing the 680.
    Cheers.
