Ask your dealer to have a set sprayed Santorini Black and switched over during pre delivery.
All dealers have a paint company they use... if done by dealer will have warranty
 Fossicker
						Fossicker
						 Defender Black Pack - grille/headlight surrounds
		Hey guys,
Have an Indus silver 90 coming in August/Sept.
Was looking at the Black Pack which I think is available for MY15 orders:
https://www.landrover.com/au/en/lr/a...er-black-pack/
Does anyone know if it's possible to get hold of a set of the santorini black grille/headlight surrounds from that pack? (picture below)
Are those sort of spare parts able to be ordered out of the UK?
Not really an answer but... those surrounds look very similar to the ones on the Limited Editions like ours, they look great but do severely limit your choice of bull-bars – almost none fit without serious mods. Just something to be aware of.
MY13 Defender 90 LE "George"
 Fossicker
						Fossicker
						Good thought. But I think Tombie is right in that its just a standard headlight surround/grille that's painted in santorini - so should have the same slim profile.
Yeah that could work - thanks mate.
Do you happen to know if the metal grille surround (not the plastic grille itself) is removable? It appears that it is also painted black.
 Fossicker
						Fossicker
						Congratulations!!!
The metal grille surround you refer to is also plastic. You have to take that off in order to take the grille off. It is much easier if you can get the whole thing painted. Taking the grille out of that surround was a bit of a pain for me when i got mine painted.
Do you happen to know if the metal grille surround (not the plastic grille itself) is removable? It appears that it is also painted black.[/QUOTE]
 Fossicker
						Fossicker
						[/QUOTE]
Thanks mate that's good to know - sounds fairly easy all in all (assuming the dealer is on the same page!). If someone's had their set painted in black aftermarket/at the dealer a picture would be great.
I would still consider purchasing an entire original santorini black set so that I have the originals should I ever want to swap them back. If anyone knows how to get hold of one let me know.
Just ask your dealer if you can buy original parts.
Came as standard trim with my white MY13 130 not sure if its paint or black plastic......will have a look tomorrow.
Black plastic, they all used to be black until the puma was released with the grey.
The 130s are still released with black I'm sure because they don't feel the need to stylise it as its more of a commercial truck.
Hence why the 130 also doesn't get released with the subwoofer like all the other models. It's not even an option!! Which is most annoying
