From my Disco workshop manual, which I believe has the same hubs.
11. Clean stub axle and drive shaft and fit hub assembly to axle.
12. Fit spacing washer.
13. Fit hub adjusting nut. Tighten to 61 Nm.
14. Back off adjusting nut 90°. Tighten to 4 Nm.
This will give the required hub end float of
0,010mm
15. Fit a new lock washer.
16. Fit locknut. Tighten to 61 Nm.
17. Tab over lock washer to secure adjusting nut
and locknut.
Some interesting reading on the topic here:
why do wheel bearings come loose?
 hub bearings
 hub bearings
