Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: How long could I leave my D4 without driving it
    Aug 2013
    ACT
    Hi,
    I have a new D4 and unfortunately will not be able to drive it for 3-4 weeks, so it will sit in my garage.
    I have a traxide dual battery, brake controller and the anti rust thing () installed. They should not cause issue but thought I would mention them,
    I have a CTEK MXS 5amp charger which I could connect to the white plug as had been described in other threads.
    Need I do anything or should I just connect the charger up for 4 weeks. If so should I leave the bonnet up?
    Richard
    Dec 2012
    Adelaide, SA
    The car will be fine for 4 weeks without you needing to do anything. I've left mine twice for 2+ months and she always fire up first go!
    LGM's Avatar
    LGM is offline Master Silver Subscriber
    May 2010
    Dongara on the Mid West Coast WA
    Let it go!
    Wot Rich84 said!
    Mind you I don't have one them anti rust thingy's
    Aug 2013
    ACT
    Quote Originally Posted by Rich84 View Post
    Thanks for that.
    Using the charger via the white plug at the back would be interesting as well, I have not done that before.
    Richard
    May 2011
    Orange Grove WA
    I would connect the charger up.
    Mine was @ 9 volts, at 5 weeks. 5 amp ctek charger on for more than a day to get it back to 100%.
    I place my ctek on every fornight without fail, even when driving it as the alternator never gets the battery to 100%, even after driving all day.
    Now when I go away, the ctek is on the car if it is not started for a period of one week or longer.
    Brett....
    Aug 2013
    ACT
    Quote Originally Posted by discotwinturbo View Post
    Brett....
    That may be the safest option as I have no idea the draw of the anti rust device or even if it works when the car us not started
    As a new car the batteries should be ok but ....
    Ruchard
    Mar 2007
    Kalgoorlie WA
    Brett....
    Interesting that you should say that Brett. I had to have a new battery this morning - the second one since I've had the D4.
    First one was replaced only 4 days after I collected the car from Barbagallo (I told them I reckoned it was 'sus when I collected the vehicle - and was proven right a few days later).
    Second battery has lasted a bit over two years (about 75,000km) - and had dropped a cell. Only warning I got was in Fremantle yesterday, tailgate latch "clicked" open / closed about three times after I had opened the upper tailgate to put the shopping in the back - after that, everything normal.
    This morning - I got dash lights etc, but no start. Landrover Assist came out and tested / replaced the battery - still under warranty so it didn't cost me anything.
    I've got a ctek charger at home - might try using it when I'm in Kalgoorlie. But nowhere to plug it into where I park while down in Perth though.
    Guess I should pull my finger out and install the Drivesafe kit I've got sitting in the shed in Kalgoorlie and a second battery.
    Cheers .........
    BMKAL
    May 2011
    Orange Grove WA
    Bmkal,
    Been doing the same on my Touareg for 6 years...battery still going strong.
    Vw does charge battery better than the D4....ie does not need charger on anywhere near as long.
    Vw keeps scratching their head at every service as to why it's still going so strong.
    Works for me.
    Brett....
    Wantirna South, Vic
    Why is this? Is it a characteristic of the charging system? Or something to do with accessories you have fitted?
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    May 2011
    Orange Grove WA
    Quote Originally Posted by winaje View Post
    Why is this? Is it a characteristic of the charging system? Or something to do with accessories you have fitted? Thanks
    Accessories not an issue for me.
    Just something I have done for a lonnnnng time. Old man started me on it.
    All batteries: buggy, quad, mower, camper, both cars....
    D4 has always taken the longest to get up to full. Smart alternator I guess to keep fuel consumption down.....but not smart in looking after batteries.
    Brett...
