There are a number of posts on this subject. "Officially", the vehicle is supposed to be put in "tight tolerance mode" which can only be done at the dealer or by someone who has the right equipment. I would very much doubt if your tyre place was able to do this or whether that are even aware of it.
There are a number on this forum that use other methods and seem to achieve a good result as well. Suggest you use the "google search" function at the bottom of the page, assuming you are on a full size web browser.
