Thread: Anti-slip paint
    Scarborough, QLD
    Anti-slip paint
    I'm wondering if anyone has had any experience with anti-skid paint. I'm thinking of using it on my chequer plate/tube side steps. I've got some anti-skid stick on tape on the tube, but obviously that won't work for the plate section.
    Would it be effective, and how long would it last?
    Feb 2009
    Mt Barker, SA
    I would suggest you look at marine anti-slip finishes, they have been around for a long time and are effective for many years on boat decks. Probably expensive tho'
    Oct 2012
    FNQ
    Use anygood paint 2 pac would be ideal sprinkle sand over while still wet then overcoat when dry or you can get glass balls that do the same
    Leasure marine stuff is to soft rubberised cork for easy on the feet and lines
    AM
    dont slide across it getting onto and off of things it will shred cloths and flesh if its any good. you did say you were putting on the checker plate on the wings right?
    Geelong, VIC
    Not sure if its the same stuff as AM is referring to, but in the past I've used a marine product (Epiglass ??) that you mixed with paint, and it expands slightly as it cures. Gave a nice grippy surface in the bottom of sailing dinghy's without being like the sandpaper style of grip tape.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
