Results 1 to 10 of 16
Thread: Recovery points on Perentie
    Mar 2014
    Hunter Valley, NSW
    Possibly a question for the Recovery forum, but as it's Perentie specific, I'll start here...
    Thinking about suitable recovery equipment for the new toy.
    Are the Perentie lift points suitable for use as recovery points?
    If so, what would be suitable attachment hardware? Is there specific equipment that works with the large holes/ bolts / inner workings of these lift points?
    As always, thanks for any advice.
    PS. I don't have a winch.
    Hay Point
    Use the tie down holes in the protrusions on the front of the bullbar. Put some rated D shackles in there. Same at the rear. The lift points are the big holes at the back of the front bar and the fold out ones in the rear crossmember, better to use the tie down points. These points are directly on the chassis rail.
    When you can afford it my advice would be to get hold of a proper perentie winch/pto. You wont be disappointed!
    Cheers......Brian
    1985 110 V8 County
    Near Seven Hills, Sydney
    Almost what Brian said...
    Your bullbar and rear crossmember have three sets of holes each. Helicopter lift points are the big holes front and rear-they are sort-of behind the bullbar on the front. Tie-down points are the pivoting bits inside the rear heli lifting points, the front tie-down point is the larger holes in the front end protrusions
    The rear recovery points are the small sized holes on a separate lug just inboard of the heli lifting points, whilst the front recovery points are the small holes on the bullbar protrusions.
    Mar 2014
    Hunter Valley, NSW
    Quote Originally Posted by Bearman View Post
    Fair enough. I was taught to never use tie down points as recovery points. However these ones do look pretty solid!
    Never used a PTO winch before. Was planning to get an electric eventually. Even better would be a 28v winch (if they exist - or convert one) to exploit the FFR system.
    Hay Point
    Quote Originally Posted by DBT View Post
    Personal choice but if you want a strong, reliable winch that you can use all day without overheating you wont go past the Thomas PTO type on the perentie. It even has an overload clutch in the PTO drive so you cant damage the winch itself as well as being capable of using at all 4 forward gear speeds and reverse. There was one on ebay recently for $1500, a bargain in my opinion.
    Cheers......Brian
    1985 110 V8 County
    Mar 2014
    Hunter Valley, NSW
    Quote Originally Posted by isuzutoo-eh View Post
    The rear recovery points are the sized holes just inboard of the heli lifting points, whilst the front recovery points are the small holes on the bullbar protrusions.
    Perfect! Thanks Mark.
    As the recovery points aren't labelled on the data plate, I wasn't sure about this.
    Bearman, agree the OEM PTO would be the best solution. For me I feel more comfortable managing / installing an electric as a DIY project. My usage will be very occasional, thus a winch is a fair way down my list.
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    G'Day DBT.
    Seems strange, doesn't it? Don't use the points designed to lift an entire vehicle with a helicopter?!?
    These points are designed for, effectively, static load ie, no sudden jerking. Compare the thickness of the front and rear recovery points and you will see which is more serious.
    I third the PTO suggestion. The con of a PTO is that if the engine cannot run, you have no winch. For this reason, we always carried a tirfor winch when on patrol. There was always the Jackall as a backup for the backup.
    In reality, with careful operation when fording, I never saw a vehicle stalled out.
    We had lots of opportunities to test the theory!
    Cheers, BDave.
    Replace "You are...!", with "Are you...?"
    Army Land Rover Buyers Guide.
    buymilitaryvehicles.com
    Reunited with RFSV 51 680, 'Sleazy'!!
    '00 VeryDisco TD5 Auto,
    Nanocom Evo for D2 TD5 and Puma
    Gone:RFSV, 51-699, Carryall 48-358.
    DO NOT use the lift points as recovery points.
    the bottom rings and the small hole on this image in the bit that protrudes forwards of the bar (aframe mount point)
    on the rear use the smaller welded tabs, not the larger rings.
    ALWAYS endevour use a bridal strap. idealy you want to keep the angle at the points under 15 degrees from parallel (165 degrees included angle between the chassis and the strap) but down to 45 degrees (135 degrees included angle) will be workable.
    The reason you cant recover the vehicle by the lift points (and its not just for choppers they're also for cranes)
    the lift points are rated to 1.5*GVM each. The tie down points are rated to a minimum of 5*GVM each. If you have it have a look at the load restraints guide.. Tied into a herc or c-17 a 110 has better than 30T worth of restraint on it. When I sling one from a crane its got... umm the wieght of the landy on it. In theory you can lift the entire vehicle from one point with the relevent safety factor still aplicable. This is to do with worst case scenario, what happens if the lifting gear brakes and its all hanging from one point I wind up with a GVM's worth of weight swinging from one hook. What happens when a plane or truck slams into a dead stop obstacle.. All of a sudden the landrover goes from an effective weight of about GVM to Lots of speed*GVM.
    I know what points I use to recover from, its not the lifting eyes.
    DONT try to use the FFR batteries to drive a winch unless you uprate the cables. Theyre only good for 100AH and if they are the proper FFR batteries are a deep cycle battery.
    Mar 2009
    NSW Mid North Coast
    I went to attach a chain to the tie down point (front) using one of my recovery shackles the other day. But the pin of the shackle is to large. What options are there?
    Use a lower rated shackle?
    Use the lower rated lift point?
    Drill out the tie down points (lowering their rating)?
    All these options reduce the mwrgin for saftey.
    if you cant get a shackle through that gopping great hole in the bottom of the front bar I dont want to know how bad you got it stuck but start digging and I'll be along in an excavator to hopefully dig it out before it fosilizes.
    The ones in the rear are ment to be used with a JATE style ring, they are a special shaped shackle that looks like a trapezium. shackles like that one are also available that fit.
    there are specialist shackles that fit them but if you're recovering from the rear why not use the pintle hook? (assuming you left it fitted) ITs rated for a shedload more than you are likely to put on performing a non snatch recovery and more than you are likely to put down if you are doing a snatch recovery (unless you over rate the recovery strap)
    the smaller holes at the front are actually the attachment points for the A frame. Yes, I have one. Yes I even have the endorsement to use it and yes, I have used it. What do I use it for normally.
    dead weight for working out with.
