                                                6th June 2014, 11:06 PM
			D4 - Tyre load ratings
					Good day all, the 19" tyres fitted to our D4s as standard are 255/55/19 111V, and this is what is quoted in the manual. What are the specs in Australia?
 Reason for asking is that its almost impossible to find an A/T tyre here that meets the load/speed rating fully - there are a couple of 111Hs around but that's about it.
 I had heard that in Oz the standard is 109H? Thanks
                                                7th June 2014, 08:33 AM
					Hi,
 The standard Goodyear Wranglers I have for mine are a 111V.
 Matt.
                                                7th June 2014, 11:20 AM
			Standard Australia OEM Load/Speed Index
					Hi Cecilh,
 This is what my MY14 D4 is coming with (from what I am aware).
 As well as an 18" option we have in OZ for the D4 3.0L.
 Standard 19" OEM - Pirelli Scorpion ATR (255/55R19) , Load Index - 111 = 1090kg, Speed Index - H = 210km/h
 Aftermarket 18" (GOE Rims) - Bridgestone D697 (265/60R18 LT), Load Index - 114 = 1180kg, Speed Index - S = 180km/h
 Cheers!
 Just thought I'd add the Topix site has JLR Approved tyres in the 255/55 range all with a rated load of 111, but speeds as low as 'S' 180kmh and as high as 'V' 240kmh.
					Reason: Additinal comment removed dribble
                                                7th June 2014, 01:00 PM
                                                #4
					The 111 part matters as that is the load rating - the speed rating not so much for most of us.  I understand that for a 4wd in some states it is ok to go down to (I think) P rating (150kmh) if you retain the correct load rating (111).  Speed rating V is 240 and H is 210 ... far above legal speeds (for most of us).
 So Cecil, 111H is fine and gives you a few choices eg. Pirelli Scorpion ATR, Cooper Zeon and General Grabber in a 19.  HTH
                                                8th June 2014, 06:47 PM
                                                #5
					All states can go down to N rating for 4wds manufactureed with off-road capabilities -
 Aust Vehicle standards Regualtion #52
 (3)     A tyre fitted to a motor vehicle must, when first manufactured, have been rated by the tyre manufacturer as suitable for road use at the lesser of:
 (a)     a speed of at least:
 (i)     for a car with special features for off-road use — 140 kilometres an hour; or
 (ii)     for another car — 180 kilometres an hour; or
 (iii)     for another motor vehicle — 120 kilometres an hour; and
 (b)     the vehicle's top speed.
 Example for paragraph (a) (i)
 A four-wheel drive vehicle.
