Whilst everything went well with the new top, I'm not happy with the fitting over the top of the doors and the way it sits at the back.
Does anyone have any pointers for what I've done wrong?
 Master
						Master
						Today was the day to fit the new rag top.
I started at the back and pulled it all forward to the windscreen which seemed the way to go. WRONG!!!!!
After figuring I could not get the front of the top pushed under the front hold down part, I pulled it all off to one side and slid it through from pass side to driver side - worked great!
Looks a million dollars compared to the old torn and mildewed one, and will now leave it for a few weeks to stretch and sort it self out before putting the roof rack back on.
Some points on the new one that my old one did not have were velcro tabs for the front of the ROPS bar, and velcro for the middle hood bow.
You can even see my 2 new Jerry Cans which came from a Trash and Treasure market today for $10 each!
 Master
						Master
G'day Alan,
Firstly close but no cigar! Lol - canopy looks great can't wait for mine to come.
Door tops - it needs to tuck in behind the door frame at the top, so pull off the rubber strips (these are there to help keep it tuck down) you will also need to loosen the tie down at the back of the door along the tub. Lift it up a bit drop it into the channel on top of the door, tie it all down, put the rubber strip back on.
At the back the rope that ties down the back and pulls it in all tight needs to go through the eyelet you can see in the photo then it goes through the eyelet in the side flap that extends past the end of the tub - then wrap the rope around the rear hoop (the left hand side needs to go around the pipe anti clock wise so it pulls everything in tight - the drivers side needs to wrap around clockwise to pull it all in tight .
then tie it off - but pull it down as tight as possible - you wont break the rope or tear the canvas.
Hope this makes sense and helps!
 Master
						Master
						Thanks Scott - I'll have another go in the daylight tomorrow.
 Wizard
						Wizard
						And the "Ears" on the rear flap that wrap around the sides tuck under the large piece sewn onto the sides. The web strap passes beneath that to go to the securing buckle. This stops the wind ballooning out the rear flap.
Quote: "and will now leave it for a few weeks to stretch.." Canvas, as it weathers, generally shrinks. LandroverScott's instruction to pull it down as tight as possible is good, as it will retain it's tensioned size. If not tensioned, shrinkage will occur, and you will never get it to sit right.
That looks greatbut I hope you have an undercover place to store your Perentie, mine came with a new canvas - but a few months down the line it has aged a lot. I've heard that throwing a tarp over the thing when parked can help a great deal.
 Master
						Master
						Good news is that mine will be under cover.)))
Sent from my HTC One XL using AULRO mobile app
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
Yes it will shrink up to 5% on the warp but hold on the weft. the warp will be along the length on the vehicle so times the length of the vehicle by 5% and that is how much it will shrink if not retrained. If you restrain it then wet it the canopy will "set" and not shrink after that.
hope that makes sense
anyway message is tie it down as tight as possible and leave it that way.
Dont forget to not leave it out in the sun too long, or it could well fade very quickly.
On the subject of shrinkage, I have seen a number of new supplied Canvas's that have already started to shrink.
