Results 1 to 6 of 6
Thread: Tail Lights
    davidjl Guest
    Tail Lights
    I am trying to change the lenses on my defenders taillights but the existing lenses will not release from the mounts. Does anyone know how I can loosen them.
    Douglas Park, NSW
    Later Defender lights have the lenses bonded to the base & have a removable globe socket for access. Sounds like you have these.
    May 2013
    WA, South East
    If you are a tight arse like me, and only bought a lens kit, you can break the existing lens and clean out any little bits with a pick. then you can reseat and seal the new lenses in.
    As said from the 300tdi onwards they are all one unit and do not come part like on the earlier ones
    I how ever do have a full set of the clear ones for the later Land Rovers which I don't have a use for anymore as I changed mine to LED ones.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Sep 2010
    Adelaide Hills in spirit.
    I also have a bunch of earlier-type lenses left over from LED replacement. All colours, some in good nick.
    Give me a shout if you want any.
    davidjl Guest
    Smile I got the answer
    Thanks everyone for that. I assumed that they were the same as Series lights, but obviously not. It seems that even in 1996 Land Rover were trying to push there trucks into the 21st century!
