Hi The side rail is in two pieces, one over the wheel arch the next below door to "B" pillar. the rail below the door bolts onto tab on the back of the first rail and is designed for when the door is off and anothe rail bolts onto the tab half way along (you can see it in the picture) and bolted to the top door hinge - a spare wheel was then bolted to this.
some wheel arch rails don't have the tab and thus you cant attached the second rail.
hopefully the photo helps
