Results 1 to 6 of 6
Thread: Repco Compressor
    Apr 2011
    Wandong,Victoria,Australia
    Repco Compressor
    Hi All,
    I picked-up a Repco Compressor today that I have been told is in good running order.
    I was wondering though - if anybody could provide some specs on it?
    I have never used or owned a compressor before, and I was wondering what size the tank was, what the HP is, and what the CFM is?
    I am new to this and am I correct in saying that you need a certain CFM if you wish to use a spray gun attachment?
    Here are some pictures - hopefully the answers to my questions are in the pictures. I did try and Google the model number but I came up blank - hence the questions...
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Douglas Park, NSW
    Going by the barcode sticker, it's a 16 CFM.
    The motor is rated at 13.5A so it's one of the bigger single phase compressors around.
    IMO it's a good size for home spray painting.
    That is a generic compressor with various brands on it - I have had the same for over 20 years and it is still running great - have painted three cars with it. They were $1100 at what is now Gasweld in about 1993.
    Make sure you regularly drain the tank.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    That's a top compressor mate. It should have a 15 amp plug on it, but I bet it hasn't - or has the earth pin ground down. Doesn't really matter - you can run a spray gun no dramas off that.
    This twin cylinder parallel compressor is still used today on several decent brands.
    That should last you many years.
    Moruya Heads/Sth. Coast, NSW
    Good idea to mount the water trap higher than the compressor, looks the goods, Regards Frank.
    Feb 2013
    Ballarat,Vic,Aus
    Is that a two stage higher pressure compressor? There's an extra housing off the back of the head?
    ie: It'll pump up high enough to do truck tires with
    seeya,
    Shane L.
