Results 1 to 9 of 9
Thread: Opinions- This is likely a 4bd1.
    Dec 2010
    Batemans Bay mostly, and Brisbane
    The fella listing this states that it is a turbo. I asked him to send through images and this is what I got...
    Mixed messages with the rocker cover detail but the rest is definitely not 4BD1-T.
    Any opinions or knowledge of the vehicle? It's a stage one out at Coonabarabran NSW.
    I was getting excited and readying the go out and hand over some money but now I guess not. I'd make the effort for a genuine 4BD1t or even a good N/A to put in my 130.
    Are there any further questions that can be asked of the vendor to verify what the deal is?
    Apr 2014
    sydney, nsw, aus
    looks like a 4bd1 to me, i dont see a turbo set up in those pictures. looks like the engine could do with a bit of reconditioning though. id be enquiring about the turbo itself to see if he could send some images and information on the condition of it.
    cheers,
    Lachlan
    Cranbourne North
    The third photo that shows a crank case breather. That is the same as my 4bb1 motor. Rocker cover as you noted is not from that motor. Would not of thought motors later than mine would still have a crank case breather. Also the intake manifold is the same as mine.
    Cheers Hall
    Feb 2009
    Townsville QLD
    Depends on the price. Definitely a 4bd1 in a stage1. Even has the cartridge type oil filter. How many miles? These engines are only looking at a rebuild when you start getting low compression. Could be a diamond in the rough that would come up lovely with a clean up job.
    Brian.
    SW of Geelong
    It's an NA engine, but the rocker cover might be from a turbo motor, or late NA.
    It's got the NA crank case breather, so the breather out of the rocker cover is extra.
    Ask him to check the large numbers on the driver's side of the block just above the sump, this will tell you what year it was made.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    WA
    Quote Originally Posted by rijidij View Post
    Cheers, Murray
    What Murray said.
    Mike Vine in QLD did/does turbo conversions that fit the turbo on the drivers side, however it does not seem to have that conversion and the breather connected to the intake would kill the seals quickly if it was a turbo.
    Dec 2010
    Quote Originally Posted by goanna_shire View Post
    Brian.
    Here's the listing:
    1984 Land Rover Defender Wagon | Cars, Vans & Utes | Gumtree Australia Warrumbungle Area - Coonabarabran | 1048835919
    He didn't know what I was talking about when I asked him about the rear doors (early 110 wind up windows) so he might not know much about the vehicle. Didn't want to talk with me for long in the phone either so asking him to poke around looking for casting numbers on the left hand side below the manifold might be stretching the friendship. I could get the engine number from him probably- is this going to tell us anything?
    However in terms of 'diamond in the rough'- a dirty engine tells no lies so it's likely ok. Electric winch on that steam engine cowcatcher bullbar. Nothing else fancy- brakes normal drums no long range tank, no overdrive or PTO etc. Pity- I was getting excited for a minute there.
    It might be a good buy for someone not too far away though. I've had two stage ones and they do grow on you.
    Kiwiland
    Could be a 4bc2, 4be1 or several others. Model is cast into the block to know for sure.
    Agree, definitely a Stage 1. I do not think it is turbo. Depending on rust (and could be minimal from that locality) it is a rare and very worthwhile vehicle. It looks to have had the S3 doors replaced by 110 ones.
