Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: IIA 88 rear shock absorber lengths
    Dec 2009
    Queensland (though occasionally elsewhere)
    Hey all,
    Apologies if this query appears elsewhere and I've been too lazy to search for it...
    A question: Could anybody suggest the correct travel for a rear shocky on a standard set-up 88? I ask because I bought some items a while back which didn't even reach the mounting points when fully extended, even though the supplier was adamant that they were correct ( I believe that they were HD front shocks from a 109 (part number RTC4235), which, according to the supplier, would be what I wanted for rear HD shocks in an 88).
    My springs are off-the-shelf replacements for the standard set-up, bought some time ago. At present they sit a little high as I haven't driven the car since putting them back in during my current rebuild. The length from eye to eye at rest is approximately 21". Even accounting for a little extra height at present, that is way longer than the maximum extension of the shocks I bought. Whatever I fit, I want to use HD items.
    Thoughts/advice/part numbers????
    Thanks,
    Jul 2009
    S.E.Qld
    Extended 526mm( 20.7") closed 334mm(13.1") for 88" rear according to an old Acdelco catalogue. .W.
    Dec 2009
    Thanks for that. Yeah, the thing is that I don't think my springs will be flattening that much when I drive it - I wouldn't want any less extension than that you quote.
    I wish I had kept my previous shockies. I'd love to know that the compression and extension measurements were on them.
    Dec 2009
    Anybody got a part number or a supplier for a heavy duty item which would fit the bill?
    Irymple, Victoria, Australia
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Dec 2009
    Thanks for that, Mick.
    I thought about ordering Pro-Comp shockies a while back, but I ran into a wall at the time when I was told that the gas shocks can't be air-freighted to Australia. Does that sound right????
    What I can't understand is that the shock which I was sent (and is listed by a lot of suppliers as the right HD item for the rear of an 88) had an extended length of only seventeen inches... I couldn't even begin to fit it.
    Mar 2009
    Brisbane, Queensland
    Hi John
    Have you tried talking to MR Automotive. I was talking to Dwayne last week about shocks for mine and he mentioned they recommended (and stocked) Boge shocks for series vehicles. AFAIK the HD front shocks for a 109 should be the same as the HD 88 rear shocks.
    Let me know what you find out. I will watch this thread with interest!
    Cheers, Martin
    Dec 2009
    Thanks Martin. I might give them a shout. I looked at the link which Mick posted here and have made an enquiry to the supplier about what it might cost to get four of the Pro Comp shocks delivered to Australia.
    The frustrating thing has been that I've tried to buy HD shocks locally, and the rear ones (despite being the part number quoted from everywhere as correct) were a good 4" to short to fit. Maybe there was something wrong with the pair sent to me. Dunno. The front ones I obtained were alright, but I will change them too if I end up going for the gas shocks.
    Not sure about the air freight issue John. I am intending to get a set myself in the next week or so.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Dec 2009
    Thanks Mick,
    Paddocks contacted me and gave an estimate of 87 quid for postage on top of a bit over a hundred quid for four shocks. I am doing some thinking.
