ARB supplies Hayman Reese towbars for defenders… prob some others do as well, but just thought I'd mention it.
 Fossicker
						Fossicker
						Hi guys just chasing some info on Reece hitch tow packs for defender 90's I didn't get one from factory and now want to add one. If anyone in or around perth knows where to look or get one from would be much appreciated.
 Master
						Master
 Fossicker
						Fossicker
						Cheers ill have to check them out
As far as I am aware the only towbar available for the D90 in Australia is the one from LRA. Hayman Reece do not make one. That said, the price of the D90 tow-pack seems quite reasonable, especially when compared to the rip-off prices for some other OEM accessories. Several threads on the forum covering this issue.
You can buy several variations of towbar imported from the UK (or import them yourself) but none are Au compliant and cannot be lawfully used for towing in Australia.
KarlB
The LR tow bar part number is RAA623 for the 90, you should be able to get one for about $400.
Note it does have a major design flaw, the electrics are on the lowest point of the bar so very easy to wipe out off road. Maybe they have changed it since I got mine about 18 months ago.
MY13 Defender 90 LE "George"
I bought the plug in harness from the UK and fitted a large round 7 pin connector bracket that puts the electrics above the square section of the bar, looks neat and well protected
Defender 90 - WEE 90
172-562 2a Workshop - Tassie Devil
REMLR 331
 Fossicker
						Fossicker
						Thanks guys I might have to call the dealer and see what the go is then, I just thought an aftermarket one would be easy to get
