Results 1 to 10 of 12
Thread: OPINIONS ON ROOF RACK VS NO ROOF RACK?
    Aug 2013
    newcastle
    I took my Windcheetah roof rack off today because the 110 is going into the paint shop to get the roof resprayed under warranty. The roof rack supports, a large LED light bar,4 single led lights at each corner, Supa Peg Supawing Awning and a alloy table & 2 chairs all the time. I took the car for a drive and noticed immediately how the dynamics of the vehicles CoG changes. Even though it isn't a lot of weight on the roof to what some people carry, but obviously significant to notice an impact.
    This I felt swayed me more towards buying a camper trailer, because I realised just how much impact that little weight has on the vehicle when driving on average to poor roads. It's hard to explain what I mean but if the road slightly leans, then the cars lean is exaggerated by the weight on the roof, how much is dependant on how much weight you are carrying I guess. I never really noticed it before but it's most probably because you just get used to it. Sometimes it makes me feel uncomforatble and I adjust my speed accordingly, but at the same time I usually do the speed limit or 10km's under.
    I actually think I will enjoy the car on windey rough roads more when driving with zero weight on the roof. Because after a long drive, 3-4hrs it can wear me down and I feel the need to pull over more regularly.
    Im doing a trip with the family to Alice Springs in a few weeks and was just chasing peoples thoughts on this. Is it in my head? Or is it that as I get tired I become more sensitive to the vehicles unrefined nature.
    May 2014
    Tamworth NSW
    I put all the recovery gear on my roof racks,
    I do notice it a bit more with additional body roll with an extra 50kg up there.
    If you are touring, (especially up to Alice), then I'd think the space you gain would be a bigger benefit than losing entry speed into corners. I guess its up to you whether a camper trailer is fit for task given your preferred method of travel.
    IMO, driving 'slow and steady' is half the fun of a landy. In my case, I've got other cars to drive if I want to hit the apex at 100km/h on a mountain road. Point is, you cant make a defender 'everything' you want in a car (race car, offroad tourer, trophy truck, mud bogger).
    Have you considered changing suspension setup to dial in the handling issues you are experiencing?
    Feb 2005
    My old setup rack and fully loaded came in at 200kg
    Have a front runner wind cheater and camper trailer ...... Still have wind cheater, shovel, RV4, event 14 and surf ski when we holiday up the beach or on one of the islands.
    Everybody does their own thing...it's whatever you are comfortable with I reckon
    n plus one Guest
    Quote Originally Posted by voltron View Post
    Roof weight makes a big difference to a Deefer's body roll and handling dynamics - I pulled my roof rack and noticed the same as you re cornering.
    That said, if you need to carry a large load you're handling is going to suffer to some degree (be it with some of the stuff on your roof or towing a trailer).
    Aug 2013
    newcastle
    Quote Originally Posted by Toxic_Avenger View Post
    I guess your right in that a decision has to be made about what you want out of the truck. I can handle the speed issue, and I realise pushing the Defender beyond its capability does make me more frustrated with it. I have changed to Bilstein shocks which have helped with ride comfort greatly as well as body roll.
    I think I will always be trying to get the most out of it, until I find its limits and then pull back a couple of notches as a compromise. Been doing that since I bought it and will probably be doing so till I dont
    Aug 2013
    newcastle
    Quote Originally Posted by n plus one View Post
    Absolutely and it was these 2 points which made me think, maybe I need something bigger like the Iveco 4x4 Daily. Then the budget master slapped me in the face.
    Oct 2010
    Adelaide Hills
    Just back from a trip to Alice on the bitumen then down and across the Simpson and back down the Birdsville tk.
    I run 180lb springs in the front and 290lb in the rear, so fairly soft. I also have Koni Raids which I installed without any adjustment to their from the factory setting. By the time I hit the 12th sandhill in the Simpson id pulled the shocks out and adjusted to max rebound. The difference was amazing both on and off road. Handles corrugations really well, handles at speed significantly better and has a lot less body roll. Also stopped bottoming out on the scalloped dunes.
    A couple of sleepers on the roof made no discernable difference to handling, but its not a sports performance machine so when I say that, I wasn't bouncing off of kerbs trying to get the tightest racing line.
    Guess what im saying is that getting the suspension right is a big part of being happy with your defender, or any vehicle really. Can take a bit of stuffing around and even then you find out it could be a lot better than what you have been running.
    Oct 2008
    One thing with roof racks on a Defender, all that weight is concentrated onto the front wind screen frame, and the rear corners of the tub. There really is not that much of anything holding a Defender roof on. At the front there is literally a few self tapper screws!. I've seen a couple of year old PUMA that had crushed the rear body down onto the chassis by running an overly heavy roof rack on corrugations. I've had the roof on a older TD5 Defender come loose just from a few corrugations on our driveway.
    AndyG's Avatar
    AndyG is offline YarnMaster Silver Subscriber
    Jan 2014
    PNG
    From memory the manufacturers limit is quite modest, ? ,
    I suppose there are two considerations:
    Structural integrity and raising the COG, increasing the potential for a rollover.
    Comfort is a distant third to me.
    From my limited boating experience COG has become very important to me, and the principal is the same, so no front winch mounted and spare fuel and water in the wheel arches. So they should counter balance any light bulky stuff up top.
    apologies to Socrates
    Clancy MY15 110 Defender
    Feb 2005
    umm, re-reading my post I must have been half asleep last night
    when I crossed the simpson my roof rack weight was >200kg, I did have poly airs in the rear spring and now thinking back I reckon having 15-20 psi in them made the truck steer alright. I was mindful of the weight on top
    the home made steel rack (120kg) has been ditched and now run a windcheetah which still gets loaded up for beach trips which is mentioned above. the other change is I am running stiffer front springs and the air were ditched from the rear and now have slightly stiffer springs in the rear as well. I am about to up the springs in the rear a little more.
    I guess I might be used to body roll coming from a 2 door rangie.......I now my wife feels the car rolls around to much and tends to drive a bit slower than I
    I guess it comes down to how much gear you need for alice......one thing is its not a windy road. If you can do without the lights and awning for the trip than I guess leave it off.
    if you are leaving in a few weeks than that doesn't leave much time to find a camper trailer.
