 Master
						Master
						Hi all, I am looking at a set of 20" rims for the d4.
My question is, will an OFfset of +45 fit with a 275/55/20 tyre?
I think the standard offset is + 53
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
 Wizard
						Wizard
						The width of the tyre will be OK with that offset. The problem could be the diameter as 275/55/20 is pretty big and will rub according to Gordon. Apparently you can modify the wheel wells to minimise this.
It would be great if you could try them as they are a good size with a few tyres available, I'm just not game to be the guinea pig.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
 Master
						Master
						That's my issue. I don't mind making a decision when informed, but guinea pig I am not
 Master
						Master
						I though the modification was only required on the 285's? Gordon, are you able to clarify at all? Also in the offset?
I can confirm it will rub, I just remembered Discowhite on this forum, had 275s on 18s and they rubbed on the standard offset, so I would imagine the mod would need to be done to the wheel well with that size, you're right on the limit of rolling diameter that fits in the wheel well, at 31.9", even with the extra offset I'd say it will still rub.
Baz.
Cheers Baz.
2007 BMW R1200GS
1979 BMW R80/7
 Master
						Master
						So I guess if I dropped to a 265/50/20 it might work? Are the rang tyres in this size?
Have a look at this,
245/60-R20 vs 265/55-R20 Tire Comparison - Tire Size Calculator
Cheers Baz.
2007 BMW R1200GS
1979 BMW R80/7
Cheers Baz.
2007 BMW R1200GS
1979 BMW R80/7
 Master
						Master
						Cheers that looks promising. I'll track down the person that posted and ask for more details
