29th June 2014, 07:31 PM
no gauges
Or speedo or rev counter....I can see a blown fuse..defender 2012.
Gingz
29th June 2014, 07:58 PM
Fuses can fail due to fatigue, have you tried another with the correct rating yet?
29th June 2014, 08:02 PM
The breakdown section is for breakdowns.
Moved to "Defender".
30th June 2014, 10:20 PM
#4
Got the problem fixed....
Background in case anyone is interested, I had the car in storage for 10 months, battery disconnected and up on axel stands, when I went back and connect up the battery everything worked but the instrument cluster.
I went and sought advice from Lifesytle 4WD in WA and he advised to remove the terminal from the battery again and reconnect....and hey presto the instruments was working fine
