Results 1 to 10 of 15
Thread: Loss of Drive in my110
    Hi all
    My 110 decided out of the blue to lose all drive
    So wife was driving and said she changed gear and there was no drive in any gear
    When I got there tried the car
    Won't go into gear with out clutch so I thought I would just drive home with out the clutch.( not the first time I have done it in my time) . Turned off engine and put into gear and the started engine and the car sat where it was in gear with the engine running. No noise from any thing nothing. Turned of car and put into diff lock then started it again and still nothing.
    The slave and master are not leaking and look fine. Fluid level is full and no signs of leaks.
    Thought at first , it might be the folk but the clutch would still work if that had gone as all that does is disengage the clutch.
    The car was running fine at the weekend. Normal clutch pedal and no slipping clutch , car running fine.
    Any ideas of what it might be. Bit if a new one on me
    Ali
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    East-South-East Girt-By-Sea
    1.20 MB
    Has it slipped into neutral in the transfer box?
    If it is engaged in high or Low transfer, try engaging the CDL. If it drives with the CDL locked, you may have broken a CV or axle. Just noticed you already checked that.
    Not good Ali, Possibly stripped main shaft splines / transfer input gear? assuming its not jumped into neutral as opposed to high/low
    Tried that
    Tried low and high and in CDL
    Still not working.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Quote Originally Posted by Psimpson7 View Post
    I am hoping clutch but am thinking it is the lay shaft in the gear box or something like that.
    Was hoping that it had jumped into neutral in the high low lever as that is what it felt like. But no such luck.
    Biggest problems was my wife call me to meet here with the car so I was in a suit so could not really get under it to have a look.
    Car now at Greg Tunsalls in Cleveland as I thought if I get RACQ to take it home I have to then tow it somewhere again anyway.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    Jan 2012
    Melbourne, Victoria
    Sounds nearly identical to what happened to my 110 a month or two ago.....
    Driving along, everything was normal, came to a corner so went to go for fourth gear but I just couldn't select it, tried all gears but the same story, clutch felt normal, once I was stopped I tried but couldn't get it into any gear, then after a few goes of turning the engine on/off I could select gears but there was no drive at all, tried high/low and difflock etc but still nothing, turned out that the centre of the clutch friction plate was half separated, sounds to me like your Def has the same trouble....
    Easiest way to find out is to pull the round plate off the transfer case just behind the gearbox and get the engine running, put it in gear and let the clutch out, if the output shaft is spinning then it is not the clutch, if it's not then I'd be willing to bet the clutch plate is the problem..
    Didge Guest
    I have no idea of the cause but out of interest how many kms on the car?
    Jan 2012
    Melbourne, Victoria
    It's a 1995 model and has done 412k, according to the previous service records it had a new HD Valeo clutch fitted at approx 220k from memory.
    I'm pretty sure the reason I couldn't select gears at first was because of a loose spring stuck between the pressure and friction plates... Maybe! The clutch felt normal the whole time so not sure.
    Didge Guest
    Puzzling - no horrible noises when it lost drive?
    Quote Originally Posted by Didge View Post
    250,000 ish. But not done much work in the last 6 years I have owned it.
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
