Thread: Can I remove rear headrests in 5 seater M4 TDV6 D4
    Aug 2013
    ACT
    Hi,
    Went to put some kids seats in the back today for my grandkids and was unable to remove the rear head rests so the seats would fit properly.
    They can be raised to the first notch only and then get stuck.
    Can they be removed is there some trick to it.
    Thanks in Advance
    Richard
    Update
    I had another look. There is a button on left side facing the head rest which needs fro be pushed and there is what looks like another one on the other side. The left side one protrudes a fair bit but the other one is flush. I did try both but had not success. May need another go.
    If I can't get out the kids seats will not fit properly.
    Jul 2011
    Toowoomba
    You're right
    Hi Richard,
    You're right, push both Buttons in & then the headrest can come out.
    I think you need to have 7 arms to do it all at the same time, I usually call for assistance ............
    Richard
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by kiwirich View Post
    Hi Richard,
    Richard
    Richard is correct but it's not easy to do. The buttons have to be depressed all the way below the surround and then you can pull the headrest out. Better if you have someone to help but it is doable solo.
    Aug 2013
    ACT
    Thanks for info. I will give it ago tomorrow.i was worried about breaking the bloody thing.
    I will have to use my feet I think
    Richard
    Oct 2013
    Quote Originally Posted by wbowner View Post
    Richard
    Make sure to take your shoes and socks off
