Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 145
Thread: Teaser of the Week!
    Feb 2010
    3029 Melbourne
    Teaser of the Week!
    Brains been running in overdrive lately & came up with what I think may be a good idea/solution to a niggling problem for a few of us!
    See if you can guess what i'm up to
    The FANTOM
    More pics to come --- Later
    Aug 2012
    Camden
    A handle to grab onto to get in? Going to screw it to the dash on the passenger side, closely missing the airbag
    Flattened duct to run through the wheel well for a snorkel?
    Aug 2012
    Camden
    Good guess I think. For some reason my eyes saw it as much smaller, so didn't realise. But I think you could be right there.
    Edit: Or is it much smaller and this is just a practice run for the bigger pipe?
    Feb 2010
    3029 Melbourne
    On ya Ron,
    I knew it would'nt take too long for the smarties on here to figure it out
    So what is the concensus.
    a - Flow rate should be same as 75mm
    b - no turbulence effect from spiral ducting
    c - less likely to puncture
    d - fit easily to 75mm 90 deg bend for airbox & snorkel
    e - no need to modify inner liner
    Seems to tick all the boxes.
    Will do some real world research tomorrow (FANTOM's fender coming off )
    Feb 2010
    3029 Melbourne
    Oops I forgot.
    e - Simple
    f - Cheap
    Aug 2012
    Camden
    Quote Originally Posted by FANTOM P38 View Post
    On ya Ron,
    Looks good to me. Supposedly filling it with sand before getting to it with hte heat gun will help form it without crinkles or folds. But that's just internet searching previously, not from experience.
    I will be very interested what the width and height restrictions are through there so you know how flat it should/has to be made. So thank you in advance.
    Hopefully we can confirm the ID required prior to landing so the materials can all be sitting there waiting (which I think general perspective is it should be 3 inches or 76mm)
    Aug 2012
    Camden
    Edit: Removing all evidence of my mistake
    Feb 2010
    3029 Melbourne
    My thinking is to start with 75mm pipe that way you can't lose volume just change shape in centre section to fit between liner & chassis, then you also have correct od at each end for hose fitment.
    Would love to hear others comments good or bad as to whether it should work, Cant be any worse than flexipipe surely!
    Feb 2010
    3029 Melbourne
    By the way the photo is of 65mm pipe & it took no more than 10min to heat up & flatten down with a short length of 90x45. That was a way of keeping it firly even as I pressed down while it was quite warm & held it while it cooled down. Tomorrow i will get some 75mm & precut to correct length required to clear highest point of inner liner then test fit to ensure no interference!
    Here's hoping
