Thread: D3 reversing sensor distance calibration
    Wantirna South, Vic
    Hi all. I reverse up to a concrete wall where I park at work, and have noticed that when the reversing beep turns into a solid squeal, I still have about 45cm before hitting the wall. Is there any way to adjust this calibration? I'd like about 10-15cm if possible...
    Regards, Will
    LLAMS, FYRLYTS, OL D4 Bar
    Feb 2012
    Wollongong
    That sounds quite normal, don't think you can calibrate them (could be wrong). Another reason to have unpainted bumpers ... wall, no problem if you misjudge !
    Wantirna South, Vic
    So does everybody put up with the solid noise at that distance? Seems like a waste of parking space etc...
    Regards, Will
    Quote Originally Posted by winaje View Post
    Yes - it is an aid to parking not the be and end all.
    I really do not see what the issue is. If you need to park closer than 40cm then maybe you need a reversing camera or someone to guide you.
    Wantirna South, Vic
    Thanks for the replies.
    Regards, Will
    Aug 2011
    Well, if I need to be closer than that I wait until the solid squeal and then move another 30cm back. It's not like the car applies the brakes when the solid squeal starts.
    NSW SW Slopes
    Ah, just don't drive so slowly and you'll be at the wall before you can stop!
