If my understanding of how the battery warning light works is correct, then I think it's very unlikely that a led globe will work as it can effectively "see" 12 volts on both sides of it. Have you tried a normal known good bulb in its place?
 ForumSage
						ForumSage
						Hey all,
98 110 300Tdi
I just replaced the so called circuit board for the warning lights, and changed all the globes to LED.
My battery warning light is not functioning. The globe and globe holder is fine. Where do I trace back to to check for faults?
 ForumSage
						ForumSage
						An LED will certainly work in that position (and mine does). The only position where an LED will not function with the stock wiring is the indicator dash light, as the current is expected to flow through the bulb in both directions. Biasing an LED to 12V on both sides (which this circuit does do) has the same effect on all bulbs, it stops current flowing through it and puts it out.
Is it in the right way around? LEDs are polarity sensitive, unlike normal bulbs. Sorry, I have to ask
 ForumSage
						ForumSage
						 ForumSage
						ForumSage
						so where do I start checking?
I'm not 100% sure if the 300tdi has a dumb style warning light like the county, but if it does, AFAIK the way they work is to have +ve from the ignition on one side of the bulb, and the other side goes to a warning light wire from the alternator.
My understanding is that when there is no alternator output that wire provides a ground for the light, and as the alternator wire voltage comes up to the same as the battery there is no longer any current flow, so the light goes out. Someone please correct me if that's wrong.
Assuming that's correct, then with IGN on you should have ~12v on one side of the light, and ground on the other. If you're getting ~12v on both sides of the light then I'd be looking at the wire back to the alternator, or if no voltage look at the wire back to the IGN.
Its not just a blown fuse is it? Not sure if its on a separate one to the other lights...
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
