Results 1 to 10 of 14
Thread: checking panel output
    May 2003
    On The Road
    With two panels wired in parallel,
    other than climbing onto the top of the van and destroying the cable insulation, how do I check if both panels are working?
    1. Put an amp meter in line, measure the current.
    2. Cover one panel, measure current.
    3. Uncover that panel, cover the other one, measure current.
    4. Compare readings.
    Note: by in-line I mean in series, not in parallel.
    Last edited by p38arover; 9th August 2014 at 06:32 AM. Reason: Clarification for those who don't understand
    May 2003
    On The Road
    and if I dont have an amp meter ?
    Surely you have a multimeter that measures current. Even cheapies measure up to 10 amps.
    Did you find your multimeter, Pedro?
    May 2003
    On The Road
    Yes,, besides the fact I've already let the smoke out of that particular item,, the panels combined output would be more than 10A,,
    BUT!
    the blanket system will work,,
    if I cover one panel and the system drops to 12.6 than that panel is working,,
    if i then cover the other panel just the amps will drop(which I cant measure) but NO change to volts,,
    make sense?
    Queensland
    Yes.
    But it would then mean you have to go up there and “destroy” your wiring to find out why the panel is not work?
    Usually it will be a blown fuse inside the meter.
    No need to measure the combined output if your meter can't handle it. Just measure the current output with each covered separately. Compare the readings. I assume you can get to the wiring down near the battery or connector to the car.
    I didn't really understand what you wanted to do as stated in your previous post.
    A new multimeter can be had for $5. See Mini Digital Multimeter - Jaycar Electronics
    Even this autoranging meter is only $20 Cat II Autoranging DMM - Jaycar Electronics
    More here: Jaycar Electronics - Search Results for multimeter
    Maybe Vidcam at the Hooper Centre in Toowoomba has them . They are a Jaycar stockist.
    Well, Pedro?
    May 2003
    On The Road
    dont rush me!
