The doodad under the air box is not a vacuum switch, it will be a MAP sensor for manifold vacuum and gas pressure. The gas ECU reads these values for calibration and changeover back to petrol on empty.
Changing to LPG is determined by the minimum temperature programmed into the gas ECU, generally read by a temp sensor in the converter body. Check that 1. the sensor is properly inserted into the converter and 2. that your engine thermostat is in good condition. A partly open thermostat will delay switch over time especially during cold weather. Replacing the thermostat in my Merc halved the warm up time. I usually set the minimum temperature to 40-45 degrees C which generally takes around 2-5 minutes to reach on the road.
