Hi dukemasterpro,
Are you planning to install these yourself or do you have a friendly garage?
Did you order standard arms or RRS ones?
Please advise how it all works out as I'm doing mine soon.
Richard
Hi all just about to order some parts to fix the creaking, groaning and knocking in the front suspension department after our 21,000km outback safari. Trip report to follow!
Decided to order genuine parts from overseas with Duckworths as they have been good value and efficient to deal with.
As the order is 26kg don't want to be faced with a return - by any chance can anyone confirm the part numbers needed - I have a 2009 aug build 2.7D4 ie what I believe I need is LR025610 lower control arm assembly
LR025613 ""
And I also made the same mistake as others with the spare wheel winch!
LR031746 is superseded to LR039486
They are about $450 cheaper for all of this even with the shipping.
Cheers, thanking the AULRO brains trust again :-)
 Fossicker
						Fossicker
						Hi dukemasterpro,
Richard
 Fossicker
						Fossicker
						Why not give Duckworths your VIN? That way they will be able to ensure you get the correct items.
 Wizard
						Wizard
						Even for the most trivial parts I supply my VIN to verify compatibility !
