Results 1 to 2 of 2
Thread: 98 110 washer bottle leaking
    Hey all,
    I did a search but couldnt find anything re leaks.
    My windscreen washer bottle has sprung a leak. Looks like at the motor/pump meeting reseviour.
    Is it just a O ring, or do I need a new pump?
    Jul 2011
    Logan
    Hi Serg .
    It's normally like a grommet that pushes into the bottle first then you push the washer into it.
    You do get a new grommet when you buy a new one from a parts joint like auto barn type shop. Would try pulling the motor off first and making sure the motor is seated correctly.
    Matt.
