14th July 2014, 09:11 AM
3 x FTC Decarbonizer/AW10 Antiwear packs to be won in JULY
This month, continuing our theme of assisting cold starting and operation, we are drawing 3 winners from our online customers, each to receive 1L FTC Decarbonizer and 1L AW10 Antiwear (value $218).
Details are below, and will be on our website soon...
Cost Effective Maintenance - Home
With temperatures still dropping, Cold Starts aren't going away any time soon. Use FTC Decarbonizer and AW10 Antiwear for FAST starts, with less smoke and blowby.
Used in conjunction with each other, FTC Decarbonizer and AW10 Antiwear are proven to give your engine that added boost in cold conditions. FTC Decarbonizer provides excellent ignition on Cold Starts, burning off carbon from combustion and exhaust spaces for optimum compression and efficiency.
In colder temps, reducing internal friction provides HUGE benefits! Faster cranking speed and less starter motor wear! AW10 Antiwear delivers unbeatable anti-friction for Engines, Transmission and Diffs. Added to transmissions, AW10 allows smoother gear changes, cold and hot!
________________________________________
Purchase any item online by Monday 4th August 2014 for your chance to WIN 1 OF 3 WINTER FAST START PACKS!
TO ENTER: SIMPLY PURCHASE ANY ITEM ONLINE BEFORE MONDAY 4TH AUGUST 2014, select "Promotional Email" in the "Where did you find us" option at the check out, and you'll automatically be placed in the draw. The three lucky winners will be contacted on Tuesday 5th August 2014.
FTC Decarbonizer:
• Fast cold starts
• Stop diesel smoke
• Deglaze & decoke engines
• Restore power & economy
• Reduce blowby & oil use
Correct smoke, power loss, heavy fuel consumption, blowby, oil dripping, hard starting (caused by cylinder glaze and/or carbon build up)... SHOP NOW!
AW10 Antiwear:
• Cut noise
• Stop rattles
• Reduce friction
• Reduce wear
• Reduce operating temperature
Provide massive strength increase to all engine, transmission & hydraulic oils... SHOP NOW!
CONGRATULATIONS TO
LAST MONTH'S WINNERS!
Congratulations to our five lucky winners from last month's EOFY Giveaway, who each picked themselves up a 1L FTC Decarbonizer. Look forward to hearing how you all go with the products!
John Lynch from Pitt Town NSW
Michelle Slade from Cabramatta NSW
Neville Bennett from Greenmount QLD
Samantha Dittmar from Gawler SA
Scott Fraser from Mt Martha VIC
22nd August 2014, 08:43 AM
We had 3 winners for the August draw...
M Essery (SA)
A Clough (NSW)
G Brandt (QLD)
Each won a package of FTC Decarbonizer and AW10 Antiwear targeting faster cold starts.
Our Fathers Day promo started yesterday & we'll be drawing one winner for a years worth of CEM products. Details to follow.
Brid
COST EFFECTIVE MAINTENANCE
