I tried this stuff in my RRC with a p76 V8, on dual fuel and with an alloy radiator and thermo fans. Never overheated, never had a problem. Race cars use it because it evaporates on the track if you have an off moment. I guess with a landrover it would evaporate when it leaks out of the P gasket too!
I suppose on newer vehicles which run higher cooling system pressures (and therefore temperatures for efficiency and emissions) you would need the anti-boil characteristics of glycol. Or if you venture to the snow/cold climates. But on a 300TDI which doesn't see those climates.. I guess you could run it?
