Results 1 to 2 of 2
Thread: two different styles of distributor caps?
    Hi all
    I ordered a new distributor cap and rotor for my standard 186 distributor. When it arrived in the mail the other day, i was a little shocked to see it was the style with the male type fitting ie, similar to a spark plug end.
    This is what I got:
    [ame]http://www.ebay.com.au/itm/DISTRIBUTOR-CAP-GB829-ROTOR-BUTTON-GB827-HOLDEN-6-CYLINDER-149-161-179-186-202-/201125642639?pt=AU_Car_Parts_Accessories&hash=item 2ed405c18f&_uhb=1[/ame]
    The only down side to this that I can see is that the ignition lead end caps are a little "fat" and will not provide a tight seal.
    Is this ok to use or should i return it and get and other style of cap with female fittings like this:
    [ame]http://www.ebay.com.au/itm/DISTRIBUTOR-CAP-HOLDEN-HT-HG-69-71-161-186-RED-BOSCH-POINTS-DIST-BH82-/291140879484?pt=AU_Car_Parts_Accessories&hash=item 43c959447c&_uhb=1[/ame]
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Adelaide - Torrens Park
    Either style is fine, but you have to have the spark plug leads to suit.
