Results 1 to 10 of 30
Thread: Fuse Holder Upgrade
    Jun 2014
    Waitakere, New Zealand
    Fuse Holder Upgrade
    Found my fuses yesterday, and holy crap they look less then impressive.
    As you can see number 4 on the left hand holder has melted itself in there. Turns out my heater fan is knackered.
    So after seeing this I decided to upgrade all the fuses and install two of these
    (see Hella catalogue here: http://www.hella.co.nz/3-444-532/pro...-Box---8-Fuses
    and document it a little and let you know how I did it.
    I started off by removing the plate the fuse holders sit in.
    After lining up the new Fuse Boxes I needed to file down the top edges circled in red just 1 to 1.5mm and drill out the mounting holes (6.5mm) circled in green.
    After a bit of trial and error with the filing I have mounted the fuse boxes.
    Also before I could mount them I had to tin snip a bit out of the bottom lip on the back of the plate.
    Tomorrow I shall install everything back into the truck, ran out of daylight after work today.
    If anyone has any suggestions of what I can do for the black out and convoy light fuses please share!
    Jun 2014
    <reserved>
    Feb 2013
    Sunshine Coast
    Brilliant work Bad.
    As much as I want to keep my Perentie original, barrel fuses are a bridge too far. You've just saved me a good deal of time researching which fuse holder will fit.
    Jun 2014
    Quote Originally Posted by Dervish View Post
    Brilliant work Bad.
    No worries, just make sure you get the rear terminal one and not the side terminal.
    Quote Originally Posted by BadCo. View Post
    Than.
    Than!
    THAN!
    You sound like a bloody American using "then" instead of "than"
    How to Use Than and Then (with Cheat Sheet) - wikiHow
    The difference between than and then (grammar lesson)
    Learn the Difference Between "Than" and "Then"
    Jun 2014
    Wow, is that ALL you picked me up on?
    Not to get too far off track here, but I've never heard an American use the English language like that.
    Just saying............
    That's as far as I got.
    (oh, the link to the Hella NZ pic isn't working.)
    Quote Originally Posted by neophyteguy View Post
    I'm on a number of US fora and it's common.
    Mar 2014
    Hunter Valley, NSW
    Heh. I took it on board as a Kiwi accent thing. Was half expecting BadCo to respond with "Yeah, thet's what I said."
    Nice work on the blade fuses BadCo. Was planning to do similar, but then was pleased to discover it had already been done on my 1990 model.
    Dec 2011
    Adelaide
    142.79 MB
    Does this help?
